Iam working on pressfit analysis in hypermesh using abaqus interface. Typically like like Carrier shaft and hole.
I completed the analysis using 1 micron interference radially between shaft and hole.
Is it possible for me to increase the interference to 5 micron radially using tcl scripting and postprocess the result without rerunning the simulation?
Thanks for any help!!
I think if you change your model, you have to rerun the simulation because it is a particularity of fem
