there is sometimes the case that the flux-window closes itself and doesn't safe the last modifications. This always happenens at new modifications. Is there any possibility to restore the model?
Thanks.
When you have these types of the problems, you need to send us the log file to see where the problem comes from and see if it is a Flux bug.
About the modifications, usually when you make modifications on your Flux project, Flux generates a python file, inside you have all the modification. To get this file:
Test. FLU (double clic) >> persistent (double clic) >> Jython_log (double clic).
Best regards.
