Hello ,
I am in an internship and I need your help if it is possible I will be very grateful. Normally I have to do static analyzes on TGV bogies. 1 month ago already that I am planted in the meshing of just the quarter of the bogie you will find the structure in attached.I find a lot of errors and I can not extract the mid surfaces since there is quite a lot of intersection. I tried to split the solid from each other but I did not get any results. I wait for your advices.Thank you
Cordially ,
