When I use feko , I often get the error shown in the figure. How can I solve this problem?
Hello liucass,
I see that you are using an older version of Feko. Please upgrade to the latest version. The error is in Intel MPI.
It sounds like you don't get it for every run, but occasionally? We have reported similar issues to Intel in the past and some of the issues were fixed by them in later versions and that is why I suggest that you upgrade to the latest version of Feko.
Hello liucass, I see that you are using an older version of Feko. Please upgrade to the latest version. The error is in Intel MPI. It sounds like you don't get it for every run, but occasionally? We have reported similar issues to Intel in the past and some of the issues were fixed by them in later versions and that is why I suggest that you upgrade to the latest version of Feko.
Hello Moderators,
Thanks for your advice, I will try it!
