Submitted by Joe on Fri, 10/01/2010 - 22:43
I want to know if I am going over my flash size quota. Where do I check this?
Submitted by Anders89 on Fri, 10/01/2010 - 23:04.
To do this, after compiling from the Tools > Code Gen... dialog, click the Download... button, then click the Coff Info... button. You will see a new dialog that enumerates sizes of all code and data sections in your .out file. The interesting line is the bottom most line which gives totals like this: Total memory used on target: Program = 4786, Initialized Data = 1252, Uninitialized data = 1466
The 'Program' and 'Initialized Data' will end up in flash. 'Uninitialized data' must fit in RAM. For the example above you must have at least 6038 words of flash.
