There is no connection between two geometries in my model. I created the geometries in separate components. How can I join the geometry at the point of contact. Thanks
Several possibilites:
Thanks for the reply. The contact is between a plate and solid. The top part is a plate so union did not work.
You make solid mesh with only one element over thickness?
I was still creating the mesh when I took the screenshot.
I am trying to connect the solid and shell elements
Hi josh,
Before you mesh you need to connect the two surfaces. Try extend surface option. If that doesn't help, please share your model, will take a look at it.
Please use below FT link.
https://ftin.india.altair.com:8443/filedrop/~osKE8Q
Thank you
