As seen in the image hm_getelemcheckbounds is returning 1.626 as the maximum value but if I measure the distance between 2 nodes it shows 7.137 . Are these 2 results not contradicting each other.
Hello @rk2
This is not defect, 'length' will return the Minimum length.
You can find the longest length element with following commands.
*createmark elems 1 displayed; set length [hm_getvalue elems mark=1 dataname=longestside]; set longval [lindex [lsort -decreasing $length] 0]; set longid [lindex [hm_getvalue elems mark=1 dataname=id] [lsearch $length $longval]]; tk_messageBox -message 'Longest element ID = ${longid}\nLongest element value = ${longval}';
Thanks,
Imoto
