I am trying to simulate the pull-out of a screw from a cube with some of the screw outside of the cube.
Which kind of contact interface should I use?
Thanks
I presume you are using RADIOSS solver and in that case ,create a surface to node Type 7 multi-usage impact interface and also a Type 11 edge to edge interface.
Yes I am using RADIOSS solver. So if I understand well, I should use 2 different interface in the same times?
Can you say which parameters I should use for both Type of interfaces?
Thank you very much for you help.
The recommended contact parameters for interface Type 7 are as below:
Istf=4
Igap=2
Fscale_Gap=0.8
INACTI=6
Gap_min=
Fric = 0.1
Iform=2
The recommended contact parameters for interface Type 11 are as below:
Idel=2
