Components mesh isn't merge
Updated by Altair Forum User
Hi, I'm doing a simple optimization of a plate with a central design part (fig 1). But when I solve the fem model and I plot displacement, I see that components mesh isn't merge. (fig 2).
How can i solve this problem? Thank you in advance.
<?xml version="1.0" encoding="UTF-8"?><?xml version="1.0" encoding="UTF-8"?>
1 - 2 of
21
As @tinh suggested you can connect nodes if the mesh is similar on both faces or use TIE contact.
did you enter panel tools>edges to 'equivalence' unmerged nodes?
