In a recent simulation where I modeled a conductor as a finite thickness region (having four conducting sides rather than as a 2D plane), I received the warning:
WARNING 2757: A triangle is too thick as compared to the lateral dimensions for application of the skin effect approximation
My question then is: what effect does this warning have on the simulation? Does FEKO simply ignore the triangles in question? Does it attempt the skin effect approximation anyway? Or does it use some other method to solve for these triangles?
Any help would be appreciated!
Thanks,
Mark
