Hello experts,
I am running a casting simulation with IS Cast 2019.2 and faced the error as below image.
I tried with 2 other machines and get the same error.
Can you explain what issue is this and give me some advices?
Thanks in advance!
Hi Duc_Hoang,
In preference you selected to run at the model location it seems, you can also do one thing, you can change the option in run option in inspire and also in run option in Inspire cast in preference, (try this it will work) if possible send the file if it doesn't work, we shall check.
With Kind Regards,
Sourav Das
| HyperWorks Specialist-FEA| Academic Program |
sourav.das@altair.com | www.altairhyperworks.com
Altair | Innovation Intelligence®
Secure file dropbox https://ftam1.altair.com/filedrop/sourav.das@altair.com
Hi Duc_Hoang, In preference you selected to run at the model location it seems, you can also do one thing, you can change the option in run option in inspire and also in run option in Inspire cast in preference, (try this it will work) if possible send the file if it doesn't work, we shall check. With Kind Regards, Sourav Das | HyperWorks Specialist-FEA| Academic Program | sourav.das@altair.com | www.altairhyperworks.com Altair | Innovation Intelligence® Secure file dropbox https://ftam1.altair.com/filedrop/sourav.das@altair.com <?xml version="1.0" encoding="UTF-8"?>
Hi Sourav Das,
Appreciated for your support. It worked.
I need to uncheck 'Run at model Location' in Preference >> Inspire >> run options
Thank you very much!
