Altair RISE
Nominate Yourself Now!
(Solved) Automotive Aerodynamic_Wind Tunnel
User: "Junta_20361"
New Altair Community Member
Updated by Junta_20361
Hello everyone,
I am studying for an automotive aerodynamic simulation on AcuSolve and VWT.
I am having trouble with building Windtunnel, it's about the tunnel's dimensions.
Does anyone know about the general rules to build the tunnel?
*for example:
-the ratio between tunnel's and car's dimensions?
-where to place the car (distance from the inlet)?
Greatly apprecitate every help!
thank you!
1 - 2 of 21
    User: "ydigit"
    Updated by ydigit
    The virtual wind tunnel you show in your screenshot if very small for any reasonable aerodynamics results. You might get colorful picture, but probably no useful interpretation.
    Wind tunnel dimensions:
    o 5 car lengths ahead of the car
    o 10 car lengths behind the car
    o 5 car widths on each side of the car
    o 10 car heights above the car
    o i.e., wind tunnel dimensions LWT x WWT x HWT = 16Lc x 11Wc x 11Hc.
    o The mesh farther away from the car will be coarse and increasing the wind tunnel domain would not affect the element count too much but it would still affect the B.Cs if they are too close to the car.
     Boundary Layer details
    o First layer height will depend on the freestream velocity to obtain a maximum y+<100. A first guess would be 0.2mm<y<0.5mm. Ideally y+max<30.
    o For some applications y+max<100 should still give good results
    o growth rate of 1.3
    o number of layers 5
    o all tets in boundary layers
    User: "Junta_20361"
    OP
    Thank you very much.
    Your answer is very detail and helpful.
    The picture i attached is just an example that i took on the internet.
    Beside, i also found some information in an Altair's E-book: Learn external dynamic with VWT.
    It mentioned about the tunnel size but all the dimension ratios are based on the  car's length.
    You can take a look in the E-book, page 22.
    Thank you again! :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
