is there a quick way to check for the node, where a force is applied? And if it's not the desired one, how do you change it?
I have reaction forces of a cross-section in the centroid. Now i want to attach the force to the calculated node of a RBE2-Elem.
thank you very much,
Tim
edit: i'm using optistruct as solver
