what is the difference between Solid conduction region described by surface impedance and Thin surface described by hyperbolic current density?
Conduction is greater in solids because the network of relatively close fixed spatial relationships between atoms helps to transfer energy between them by vibration. Collisions occurring at the contact surface tend to transfer energy from high-temperature regions to low-temperature regions.
For Hyperbolic Current Density, Please refer attached pdf.
Dhanasharee Jadhav
Hello;
Please refere to Flux Help, bellow you can see an extract about the thin region and surface impedance:
