Concrete is generally manufactured using solid65 element. Whereas i don't find any solid65 element in hypermesh. Which element should i use and what are the changes to the element that can be done.
Hello @sruthisreechennapragada,
Greetings!!!
I believe there are yet to add that element in to ANSYS platform of HyperMesh.
From , the following help document, you see that- they already have SOLID45, SOLID95. Therefore, it might be their on to-do list.
https://altairhyperworks.com/hwhelp/Altair/2017/help/hm/engsol.htm?radioss_bulk_to_ansys_conversion.htm
Thanks & Warm Regards,
Akshay S.Patil
Since this question is related to Ansys solver, I Suggest you contact Ansys support for the same.
Thank you
