Hi
I am doing topology optimization. I have a little bit complex geometry attached below. I want to make Solid Map mesh to my geometry. But I am getting the following error 'At 0/4: Solid must have 3 or more faces, found 2'
How can I mesh my part?
Thank you in advance
Just checked your model. For Solid mapping, you have to split your complex geometry in several 'mappable' solids.
Have a look at some tutorials of Hypermesh and TRY firstly on your geometry.
