Hi everyone,
I'm trying a new feature in InspireCast named 'Cycling'.
I need your help on my questions as below:
1. Based on my understanding, this feature will give you the result of mold temperature variation while working with multiple cycles.
Is that true?
2. Take an example that i tried on ICast2020.
The setting was made as below:
i defined the duration time = 4s (the amount of time that the mold is open before beginning the next cycle)
However, while checking the result, i found the duration time was 1200 second for 2 cycles.
Is this a bug in the software?
or if it's correct, could you explain for me about the timeline in this?
Thank you very much!
