How can i see results for a particular component in a big assembly? I know i can just Turn off all the components/elements and show only that particular component to see its results, but i have quite a few iterations and quite a lot of components to carry out this operation. So every time doing this is a painstaking process. So instead i would like to create a few groups before running the analysis like we have elements assigned in Assembly Hierarchy. So while Post-Processing i can directly Turn ON/OFF a particular group to check results. Then saving as the file will also retain the groups for further study and post-processing for other iterations.
