Multilayer Meets some Errors
Altair Forum User
We tried to build a multilayer (1 μm SrTiO3 on infinite SrTiO3 ) and also only the infinite SrTiO3 plane. The result should be the same. and the aim of doing this is to check the identity of the Green function for these layers.
However, we got error report which is attached.
Hi Haoyuephys
It seems you defined multiple layers of the same parameters. You can define one layer for these. Perhaps the idea was there should be different layers for each level containing metal? This is not a requirement in Feko.If this does not resolve your problem, please attach an example cfx that gives the error.
