SpotWeld Creation
Hello experts,
I am facing a trouble to create SpotWeld in HyperMesh - Radioss Solver.
I have a model in which the spotweld is created like below image. but i don't know how to create the spot weld like this.
I know the spotwelds can be created using connectors >> spot >> elem type = type2(spring).
but the result doesn't match my model, instead of create 1 spring2N elems., the connectors create 3.
i have watched some videos on youtube/ altair university/ Radioss tutorial. they all use this approach.
So is there anyone know how to create the spotweld with only 1 spring 2N as my model using HyperMesh?
Please show me the procedure.
I have attached the model file for your reference.
Thanks in advance!
actually only one SPRING2N element is created; the other two elements on either end of spring are plot elements (1D elements with 2 nodes used for display purposes only).
Use proper post script to realize connectors upon creation. Otherwise use the realize subpanel.
0 -
Altair Forum User said:
Hi Simon,
I got it.
Thank you very much for your explanation. /emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
