[Solved] Error 595 when importing .sta file
hi everyone,
I have found a problem when doing the multistage forming simulation with HyperForm.
Normally, we usually define the blank of a stage with the .sta file of its previous stage.
We done this by using user process >> blank >> from file:
with this method, HF works fine.
However, when i use the 'import' tool in HyperForm to import the .sta file then define the new component as blank >> the solver stop and show error 595:
I'm not sure what is the difference between 2 approach. Can someone explain this for me?
Thanks in advance!
hi everyone,
i have found the solutions for this.
The 1st method is you need to uncheck 'read INTIAL SHELL Data' in the solver options.
The 2nd method is using the user process >> blank >> from file:
However, the data of deformed blank (thickness, stress,strain) will now be stored in an include file .sta.hmx.
The include file is generated when you import the blank by 2 methods above and it is stored in the directory of the original .sta.
You also need to take care of the location of this include file.
If the include file is deleted or removed to another folder, the solver will give error: 'can not read include file' and stop.
here is a record video of the issue for your reference:
