Can anybody give some application for usage of Enforced displacement constraint?.
Is is used as an alternative of force?
Thanks,
Sam George
Hi
Enforced displacements are used when you don't know the magnitude of a force applied to a part, but you do know how much the part displaces as a result of that force. Also, we use it when we need less than a particular amount of displacement in the particular direction.
Thank you
