Submitted by Joe on Tue, 03/22/2011 - 20:35
I need a 1 microsec output pulse on a GPIO out pin. I will need to set the pin low, delay 1 microsec, then set it high. I know there is a NOP instruction which takes 1 tick. How to I use that?
Submitted by Anders89 on Tue, 03/22/2011 - 20:43.
You can use the externFunction block to create a small delay loop by putting the following C loop into it:
{ int a; for (a=0;a<10;a++) asm('NOP');}
Note that though the chip clock is 100 MHz, the loop count is only to 10. That is because one loop iteration takes 10 ticks due to an 8 tick pipeline stall + 1 tick NOP + 1 tick inc/compare loop counter. Then write a 0 to the GPIO above the NOP delay, and write a 1 to the GPIO below it. VisSim generates code for parallel flows in top down order, so you will get a 1 microsec low pulse.
See attached diagram below (you must be logged in to see it).
