Hi all,
How to find the smallest element and corresponding component by script and only show the component in the display window and highlight the smallest element?
Roy
Why do you need to do it by script?
A convenient button should be defined for simple use. So I want to script this. Could you help me with this?
I don't know direct command, a way to do is
-use *elementtestlength with a given threshold
-it will raise a message reports min length
-take that min length and use *elementtestlength with that value
But the message will be delay because it is raised by a timer proc
So you have to wait for it (tkwait)
If min length is shortestside, we can use hm_getvalue very easily.
