I imported my model with CFD tetramesh elements (Fluid 30) to ANSYS ADPL. The outer layer of the CFD elements were all missed. Anyone has similar problem before?
Hi jacobier,
Please can you tell me in which profile you have meshed the model and how did you export the model?
thank you
Premanand
I used the ANSYS template to open my mesh file. And I export the mesh with ANSYS file type and template as .cdb file. I have tried to just export one outermost element from my CFD component and it also failed.
Hi
I think I found the problem:
I used solid45 and fluid30 for the simulation. These two elements do not have a pyramid option. So when transport HM mesh to ANSYS, all these elements will be gone.
Thank you anyway.
