Submitted by Joe on Sat, 01/09/2010 - 06:34
We need to know how to change vissim+ccs 3.1 to vissim+ccs3.3. CCS3.1 and CCS3.3 both are installed in same pc. Please advise
Submitted by Anders89 on Sat, 01/09/2010 - 06:44.
Do not uninstall your current version, simply download and install the latest ECD on top of your current installation and it should automatically update necessary files.
If you have an F28xx target, edit \vissim70\dsp\dosrun28.bat in notepad, and change the first line from: set CG5DIR=C:\CCStudio_v3.1\C2000\cgtools to set CG5DIR=C:\CCStudio_v3.3\C2000\cgtools
If you have an LF240x target, edit \vissim70\dsp\dosrun24.bat in notepad, and change the first line from: set CG5DIR=C:\CCStudio_v3.1\C2400\cgtools to set CG5DIR=C:\CCStudio_v3.3\C2400\cgtools
