Submitted by Viswanathan on Wed, 07/08/2009 - 19:58
Is it possible to literally invert a hex number in VisSim
eg. If I have 0x1234 (0001001000110100), can I get it as 0x2C48 using any simple operation?
Can I write my own C-code / assembly code and create a VisSim block out of it. A value should be passed into the block for proces.
Submitted by pete on Thu, 07/09/2009 - 10:29.
Hi Viswanathan,
You can use the '~' ones complement operator as a prefix to your number in a const block,
or you can use it in an expression block.
Pete
