Logic after PWM
Updated by Altair Forum User
Submitted by akowal on Fri, 05/11/2012 - 00:54
I was wondering if it is possible to essentially 'process' (i.e. test with logic, and run through algorithms) the PWM signal in VisSim. I get how to make a PWM signal using the ePWM block, just not sure how I can go about using this generated signal afterwards. Would I just use the GPIO pin that corresponds to that particular PWM output? I'm using a 'delfino' F28335, on a peripheral explorer card.
