Submitted by Joe on Wed, 05/02/2012 - 04:11
I was hoping you can clarify something for me. In your ePWM block for the 2806 you have an input which is % Duty Cycle A(1.16). Can you define what you mean by this? Since this ePWM module uses an Action Qualifier I’m not sure what you mean by 0% or 100% duty cycle. Our block for the ePWM is as below:
.png.8e206d990a576511223700146b33c154.png)
So if I set % Duty Cycle A(1.16) input to 100% (actually 0.99997) does this mean CMPA will hit at the start of the up count and the end of the down count OR will it hit near the top of the up count and near the top of the down count?
Thanks
Bruce
