I trying to import far field radiation pattern from an external data file but I didn't get, shows Format error while loading the file.
Can you help me please..
Hi Sirajudheen, Is it possible to attach the file you are trying to import?
Hello @Sirajudheen
For others to be able to assist, it would help if you could explain what you would like to do with the data and what format the data is in.
Are you using CADFEKO to import the radiation pattern to use it as a source in further simulations? If so, please refer to the 'AR Card' documentation for the required format.
Kind regards
Madelé
