Multiple Fibre Orientations in ply
Updated by Altair Forum User
As far as I know its only possible to assign a single direction to a composite ply. However, lots of plies used in the composite industry are not unidirectional. For example a 0-90 ply. In this ply half of the fibres has direction 0 and the other half 90 degrees. How can I mimic this in Hyperworks/optistruct for an FEA?
1 - 2 of
21
Hi Ivan,
Thanks for your Reply, this is exactly what I needed, /emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
composite plies are modeled with MAT8 orthotropic material, where
-E1 is Modulus of elasticity in longitudinal direction (also defined as fibre direction or 1-direction)
-E2 is Modulus of elasticity in lateral direction (also defined as matrix direction or 2-direction)
The material properties is what defines whether the ply is a uni-directional or bi-directional.
Unidirectional plies have E1>>E2, while bi-directional have E1~= E2
