Many functions (e.g. geom-quick edit, 2D-Automesh, ...) render the geometry transparent, making it impossible to select individual lines (see screenshot).How to disable the transparency?
Thank you
Nico
Try 'by 2D topo' for solids, your life will be better in this case /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
or maybe Mixed...?!! so if you have different components, it is easy to visualize...
or... click on below 'monitor' icon, and then set 'Solid transparency' to a lower lever
