In The Name Of GOD
In Version 13, there is a sub panel quite edit on the Mid surface panel. But it's not in version 14. Where should I find it in version 14?
thanks.
In final edit tools, select assign target option which is used to repair or edit a midsurface by correcting its targets.
Thanks a lot George.
