I am getting the following warnings while simulating an Impedance transformer. Please, let me know what needs to be corrected.
Thanks.
The model is attached.
Hi SSachdeva
The message indicates that you are exciting (or trying to receive at the 2nd port) the waveguide at a frequency where there is no propagating waveguide mode.
Are you perhaps simulating over a too wide frequency range? Then your start frequency should be set just above the cut-off frequency
