Submitted by Joe on Sat, 09/12/2009 - 03:46
Hi, I just want to check & test all the blocks in the library. Okay, let’s say I am using the compound block. If I tick “enabled execution” in the compound block, then can I use the readInterrupt block to control the block execution?
