Submitted by lukasovich on Thu, 12/08/2011 - 05:38
I have spent huge amount of time to make this example working, but I still don't know how. I use TI PFC & Motor Developers Kit, with Anaheim BLY172S-24V-4000 motors: http://www.anaheimautomation.com/products/brushless/brushless-motor-item... included with Kit.
Problem occurs in sensorless mode. I followed instructions for motor starting, so I first started motor in open-loop until it reached a least 0.25 of max speed. Then, I turned on sensorless mode and then motor stopped still producing noise (I suppose that motor fall out from synchronism).
I tried everything, changed parameters but still got the same error. So, could you write the details about this? I need to know:
1 Did you use TI PFC & Motor Developers Kit with included Anaheim BLY172S-24V-4000 motors?
2 When displaying SMO estimated angle and generated RAMP angle (used in openloop mode) is there phase shift between them or there are in phase? In my case estimated SMO angle and RAMP angle were not in phase, there was phase shift between signals.
If someone experienced the same or similar problem with this example, please answer to this post, it would help me a lot.
