I have to perform a thermostructural analysis on a piston in order to obtain the final stresses and displacements due to thermal and mechanical load. I ve done a thermal analysis in order to obtain nodals temperatures due to an heat flux with convective surfaces. Now i have to import this nodal temperatures on the final model to obtain the final resuls. I have tried with the temp load but it doesen't work. The problem is to import both the load step (structural and thermal) in order to have final displacements. In the thermal one i have also an heat flux so i can't use tempload with load collector becaouse i need the whole loadstep. I put the model down here if anyone could help me.
