Hello all,
When we create a node by using *createnode command, how can we get the corresponding node id correctly?
Thank you
Roy
<span>for getting latest node id hm_latestentityid</span> <span>nodes</span>
<span>for getting <span></span><span></span>latest <span></span>node <span></span>id hm_latestentityid</span> <span></span><span>nodes<span></span></span>
Thank you @vipin
Should the hm_latestentityid command next to the *createnode command?
yes @Roy Duan, after the *createnode line.
