I have been struggling to pick nodes from the screen, specially when the node I want to pick is the independent (centre) node of an RBE (spider) with lots of dependant nodes. This did not use to be a problem in older versions. Do other people have this issue and is there any way around this problem? I have tried to adjust the 'node tol', 'pick tol' on the mesh option but it did not help.
Thanks
