Submitted by sachingaikwad on Tue, 05/08/2012 - 00:29
Please explain radix Point in VisSim fixed point blocks. Is it base or exponent to 2? I have a problem with converting value 1.32 to 1.16 is it correct to use convert block or not?
Submitted by Anders89 on Tue, 05/08/2012 - 01:01.
Radix point is the binary equivalent of the decimal point in the VisSim/Fixed-point block set. In your example of 1.32 and 1.16, the radix point is 1 in both of them. This means that you have 1 bit of integer magnitude in a 16-bit and 32-bit word respectively. So the remaining bits are fractional. Because we use 2's complement notation, the top most bit is the sign bit. Yes, you can use a VisSim convert block to convert between different fixed point word sizes or radix points. What was your problem exactly?
