Whenever I create a mesh whether it is 2d or 3d,and then I go for elements check I get a question which parameter should I check and correct first (like in 2D first checking warpge then correct all failed elements then check aspect ratio, correct failed elements).Is there any sequence that should be followed to get good mesh and save time??
Thank you.
