I'm doing a transient magnetic - steady state thermal cosimulation of a motor. I've set everything following the flux guide and started solving the problem.
   	However on the thermal side I get an error saying 'Unable to calculate torque : there is no air zone around mechanical set : MECHANICALSET_ROTOR'. I didn't have this problem on the magnetic side and I had previously solved the transient magnetic problem and got a torque value correctly. What am I doing wrong here?
   	By the way, the airgap is set manually to an air material that I have created that has similar properties to air. I think I did this because in the past I had problems when I set the airgap to be compressible air (or something like that).
