Hi all,
i want to use the Particle Replacement routine in EDEM 2022.0 vers. 8. After setting up the tutorial i get the following warning in the particle-particle plugin window.
The simulation does not start and i have no clue what i am missing. The tutorial pdf does not specify where i need to put the files located in the src folder also.. So i am not sure where to put them.
Thanks for your help!
WARNING : Plugin : Could not locate method:
GETCMINTERFACEVERSION
In plugin file:
C:/Users/vo7742/Desktop/Austausch/SIMULATIONEN/EDEM/Eirich_0.1/ParticleReplacement.dll
