Hi, when I create a spring with zero length how I can understand which are the dofs? The dofs are the same of the global reference system ?
directions can either be global or local. Local directions are defined with a fixed or moving skew frame (skew_ID). If left blank it follows global reference system.
From Radioss help:
https://www.sharcnet.ca/Software/Hyperworks/help/hwsolvers/hwsolvers.htm?springs_guidelines.htm
