Hi. I want to solve the problem about erp reduction by free-size optimization(design valuable is only thickness)
It looks like easy problem but I want to know exact process.
If I have plate 180 [mm] x 180 [mm] and property = pshell (thickness = 2.5 [mm]), I want to reduce equivalent radiated power by size optimization by thickness distribution.
I want to set under bound = 1 [mm] and upper bound = 5 [mm].
It means that initial thickness(2.5 [mm]) can change 1 [mm].
Would you plz let me know how to set desvar, generic relationship in free-size panel in optimization panel.
Thanks a lot.
