How to create meshing between overlapping components on node to node basis
User: "Altair Forum User"
Updated by Altair Forum User
Hi all,
i am currently doing a FEA on truck chassis frame. In this regard, I have a model made up of assembled components and want to mesh the common surfaces having the same number of mesh seeds as shown in the figure. I have also attached a screenshot of the actual model where this has to be done along with the model file.
Thanks for the help in advance.
Kind Regards,
Shreyas
1 - 2 of 21
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    You need work more to get good surface model. Have a look at my screenshots:
    In this example, I used : Surface Edit => Extend Surfaces
    HTH,
    OP
    Dear Nguyen-Dai,
    Thank you for your quick reply.
    I will follow the suggestions you have given and prepare the model. Can you also please suggest a method for meshing as well?
    Any help is duly appreciated.
    Shreyas
