I'm working on an analysis starting by a thermal analysis and continuing by a mechanical analysis. The system is modeled using shell elements and rigid elements for the bolts. During the thermal analysis there's no conduction through the rigid elements, how can I implement them ? By using an interface between the surfaces in touch ? How ?
Thank you in advance,
Xavier
