Hi all,
The EDEM 2026.1 Windows installer (AltairEDEM2026.1_win64.exe) extracts to 100% ("InstallAnywhere is preparing to install...") and then closes without the setup wizard appearing.
It fails the same way in GUI mode, console mode (-i console), and Windows 8/7 compatibility mode, run as administrator. Running it with "start /wait" returns exit code 3004.
Debug console output (Ctrl held during launch):
Invocation of this Java Application has caused an InvocationTargetException. (LAX)
java.lang.NoClassDefFoundError: Could not initialize class com.zerog.util.ZGUtil
at com.zerog.ia.installer.LifeCycleManager.br(Unknown Source)
at com.zerog.ia.installer.LifeCycleManager.init(Unknown Source)
at com.zerog.ia.installer.LifeCycleManager.executeApplication(Unknown Source)
at com.zerog.ia.installer.Main.main(Unknown Source)
at com.zerog.lax.LAX.launch(Unknown Source)
at com.zerog.lax.LAX.main(Unknown Source)
System: Windows 11 25H2 (build 10.0.26200), Ryzen 9 7950X3D, 64 GB RAM, RTX 5080.
Already ruled out:
- Ran from C:\temp with TEMP/TMP redirected there
- No Zero G registry file present
- No JAVA_TOOL_OPTIONS / _JAVA_OPTIONS set
- No Defender detections or Smart App Control blocks
- No crash events in the Windows event log
- Locale en-GB, code page 1252 (UTF-8 beta off)
- LAX_DEBUG=file produces no jx.log
Has anyone seen this on Windows 11 25H2, or found a workaround? Is there a newer installer build that fixes it?
Thanks!
