I'm trying to do a simulation with HyperMesh on a cylinder with the bottom fixed and a axial moment on the top.
As suggested, I create a node in the middle of the top surface of cylinder and use RBE3 to tie the node and every node of the top surface together with dof123456 activated. Then I apply a axial moment on the node I created. But the simulation doesn't work: there is only a disk in the result.
When I change the moment in to a normal force, it works, so I think the problem lies in the moment.
Could you help me?
Thanks!!
