Hello everyone, I am attempting to build a dynamic model of a semi-trailer using a "slipper spring" suspension system.
This type of leaf spring assembly lacks a fixed shackle mount on the chassis; instead, the spring end simply slides against a contact surface on the chassis.
When constructing the dynamic model, I applied an "Impact" function between the leaf spring and the contact surface to handle the interaction. However, during a drop test, the model's behavior causes the spring and axle assembly to fly off the contact surface; I am currently applying the Impact function only in the Z-direction.
How should I model this to accurately reflect the actual motion of the semi-trailer? I would greatly appreciate your advice and solutions.
Thank you very much, and I look forward to your feedback.
HuanRose
